Would turning motor over by flexplate cause spun bearing ???
Old Dec 9, 2007 | 12:31 PM
AZ2ENVY's Avatar
My car hasnt been started since late august cuz the trans
has been out of it . I turn the motor over by hand and flexplate
2 3/4 turn once a week to keep the valve springs from fatiguing
because the size of cam I have in it . Would this cause ANY problems
from me doing this because theres no oil circulating to the top
of the motor ? Thanks in advance
Old Dec 9, 2007 | 12:40 PM
Stl94LT1's Avatar
No, shouldn't be a problem.
Old Dec 9, 2007 | 12:41 PM
96capricemgr's Avatar
I can't see it being any problem.
If you want to move some oil turn it over with the starter after removing the pcm fuse and crank till you see the oil pressure come up. Don't get carried away or you will cook the starter. A friend has a kill switch on his Impala where he never lets it fire till it has oil pressure, starter actually handles it amazingly well. I am not really convinced that it is necessary with normal use of a car but can see a benifit for a motor sitting long term.
Old Dec 9, 2007 | 12:52 PM
AZ2ENVY's Avatar
Thank you very much for the help
HectorM52
Jul 30, 2017 11:46 AM
StansZ28
Feb 19, 2015 07:39 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
formula79
26
Aug 5, 2002 12:21 PM
