Would poorly adjusted rockers cause this?
Old Apr 3, 2005 | 09:21 PM
NVRLATE's Avatar
I just put in a cam and haven't had a chance to drive it yet. I did however fire it up for the first time and to my surprise it started right up. I have comp R lifters with NSA pro mag rockers. There is so much noise coming from the engine from all 16 rockers it's hard to tell which one(s) are clacking . I have a very rough idle and when I put the car in reverse to get it out of the garage it doesn't respond to the gas pedal very well. The brakes also are very weak. My question is would poorly adjusted lifters/rockers cause the car to run that poorly .
On another note the car sounds nasty and it's idling around 600RPM.
Old Apr 3, 2005 | 09:24 PM
Spinner's Avatar
Re: Would poorly adjusted rockers cause this?
Sounds like the valves are hanging open... no vacuum
Old Apr 3, 2005 | 09:25 PM
95_LT1_6SPD's Avatar
If your rockers are clacking that badly i would re adjust them.
Old Apr 3, 2005 | 09:27 PM
NVRLATE's Avatar
What would cause that?
Old Apr 3, 2005 | 09:29 PM
NVRLATE's Avatar
I forgot to mention that the PCM has not been reporgrammed since the cam install.
Old Apr 5, 2005 | 10:48 AM
NVRLATE's Avatar
Can somebody else chime in?
Old Apr 5, 2005 | 01:25 PM
The Cartel's Avatar
Rockers being to loose AKA the clacking sound...
Old Apr 5, 2005 | 03:31 PM
BUBBA's Avatar
I'd certainly get the cam programmed. I believe therein lies your problem. JMHO
Old Apr 6, 2005 | 11:08 AM
NVRLATE's Avatar
Will loose rockers will cause hanging lifters? That was my question for Spinner. I know that loose rockers cause the clacking.
Old Apr 6, 2005 | 11:44 AM
The Cartel's Avatar
I don't understand "hanging lifters" If your talking about hanging valves open, then yes it will. It's not providing enough pressure to close them properly.
Old Apr 6, 2005 | 12:46 PM
chevy1963's Avatar
hanging lifter are when the the Rockers are not tight enough on the push rod. When the push rod doesn't push the lifter back done on the cam properly, "HANGING LIFTER"
I just did my heads and cam. The brakes are prolly due to lack of vacumm to the booster, make sure you put the vaccum hose back on the intake that is from the booster.
I had to adjust th rocker last night, I ahve Comp "R"s and 1.6 CC pro mags.
I had the car running and pulled the drive side cover off and adjust all the rockers, this way you can do hear the clicking. I shut car off and did the same to a passenger side.
Old Apr 6, 2005 | 02:01 PM
NVRLATE's Avatar
My bad I meant "hanging valves". Thanks for the info guys.
Wart Hog
Sep 8, 2015 05:53 AM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
