Would this pass emissions?
Old Feb 28, 2006 | 02:26 PM
1 Nasty Bird's Avatar
About to loose my license over emissions here. I have long tubes off road Y pipe and catback. Im not too worried about no cat, ive heard of cars passing without em. But i also have a 3600 stall. Im afraid the revs will be so high when they put it on the dyno itll fail. Would the stall hurt it alot, or would it run pretty clean since the motors not really loaded till the converter spins up to a certain RPM? Its also been reprogrammed by madz28 witha lil timing advance thrown in. I think i might have too much against me, but ive had stock LT1s reading so low youd think the car was idleing the whole time. Its got fresh plugs n wires, any other tips oir tricks?
Old Feb 28, 2006 | 02:37 PM
Re: Would this pass emissions?
I know i can get failed automatically for no cat, im not so much worried about that as i am it actually passing the sniffer. Humm i also killed the EGR, and air. Air is fine it only works when warming up, but the EGR might cause some high readings. Ive got isses
Old Feb 28, 2006 | 02:39 PM
km9v's Avatar
I don't understand why people do these things to their cars when they know they have to pass an emissions test.
Old Feb 28, 2006 | 02:40 PM
Ill get throught it one way or another.
Old Feb 28, 2006 | 03:43 PM
2000GTP's Avatar
Stall or no stall, if you have removed your cat, you will most likely fail the visual test if it is performed, and you will most likely fail the tailpipe test. Aftermarket cats from Carsound, Catco, or Pypes are not that expensive.
Old Feb 28, 2006 | 03:56 PM
StephenDeli22's Avatar
Not to highjack this guys thread, but is 280 bloody rape to weld in a high flow cat?
Old Feb 28, 2006 | 03:57 PM
rkinney's Avatar
As far as the EGR goes, I passed the emissions test with egr disabled. I was running a zz3 cam, and put the converter on to pass the test. I changed my oil, went straight to the testing facility and passed while only registering a third of the limit on about all categories. Granted the zz3 cam is small, but I was expecting higher NOx numbers due to egr being deleted. I use a carsound cat that just slips into my y-pipe. I guess the greater overlap of the cam performed the egr duties for me.
Old Feb 28, 2006 | 03:58 PM
2000GTP's Avatar
Yeah, I would say so, I had two high flow cats welded into my y-pipe and it ran me 150 bucks.
Old Feb 28, 2006 | 05:01 PM
94arcticwhiteM6's Avatar
i had one installed yesterday for 125 bones
Old Feb 28, 2006 | 06:16 PM
I think im gonna put some washers on one of the exasut flanges and try to dump some exaust before it makes it out the tailpipes. My ex's car just was passed with a MASSIVE exaust leak (SUPER LOUD) with flying colors in a shadier part of town. Ill put a nice gap after the muffler before the tailpipes and hopefully dump some exaut through there and maybe i can talk one of the techs into leaving the sniffer half hanging off or something.
Also gonna be running on alotta alcohol i think! Im gonna drive it till empty soon after to get it out of the system as i hear it can be bad for o-rings?
Old Mar 1, 2006 | 04:59 PM
2QUIK6's Avatar
Remember the higher the octane content, the higher the HCs are going to be because the fuel takes longer to burn, so use the lowest octane fuel. The extra timing should help you since it will give more time for the fuel to burn completely.
As far as the EGR, if you have a cam that is similar in overlap to the LT4 style cams you're ok..the LT4 motors do not have an EGR because it is redundant due to the intake/exhaust overlap.
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
