Would like some info on this kinda of custom cam.
Old Feb 8, 2005 | 11:03 AM
fesgali's Avatar
I've been thinking of getting a cam and thought about a custom grind. 230/230 .595/.595 at 112 lsa with 1.5rr
Any ideas on what that would give me? Is this the right path for a mostly NA motor with possibly some n20.
The heads will eventually be ported/polished but for now it'll be on a upgraded valvetrain only.
Old Feb 8, 2005 | 11:34 AM
SStrokerAce's Avatar
Re: Would like some info on this kinda of custom cam.
Looks like a Solid Roller Lobe with that kind of lift and a 1.5RR, Seems odd to have that duration even and the LSA that high together.
Bret
Old Feb 8, 2005 | 11:44 AM
'94 Bad A Z28's Avatar
You want a split duration cam for nitrous.
Old Feb 8, 2005 | 09:45 PM
Deenasty's Avatar
im running a 240/240 .595/.595 112 with 1.6's....Yes you want at least 6 degrees more on the exhaust side for n20..
Old Feb 8, 2005 | 11:30 PM
the split is more dependant on flows, curtain sizes and lobe areas.... that can get a little bit more in math than you need to get. A N2O cam usually likes a lot more exhaust duration than even a NA motor, and based on calcs like that a typical SBC likes more duration on the exhaust.
Bret
Apr 3, 2015 10:54 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
CARiD
Jan 14, 2015 04:00 AM
brandboZ28
Jan 31, 2003 06:19 PM
super83Z
Jul 11, 2002 10:16 PM
