Would A Grade 5 7/16 X 20 Enough To Put My Crank Hub Back On??
Old Jan 8, 2008 | 12:19 PM
playa7970's Avatar
I picked one up just incase but would it be ok since i couldnt find a grade 8??
Old Jan 8, 2008 | 02:52 PM
Threaded rod or bolt?
Either way, chances are it will strip.
Old Jan 8, 2008 | 02:55 PM
G. McDonald's Avatar
Grade 5 bolt/threaded rod
For what it's worth, I bought a length of grade 5 threaded rod (couldn't find grade 8 either) and it worked fine for me. I used a length of pipe and some thick washers to push the crank hub on and it worked very well. I also used the same length of threaded rod to degree in the cam and turn over the engine to install the roller rockers and it was a trouble free solution. Good luck.
Old Jan 8, 2008 | 06:29 PM
playa7970's Avatar
is there a tool i can buy from summit racing sinice they are like 5 min away from me
Old Jan 8, 2008 | 09:25 PM
ricehammer's Avatar
You can get grade 8, 7/16-20 threaded rod, and the nut and washers, from McMaster Carr http://www.mcmaster.com/.
Old Jan 8, 2008 | 09:52 PM
Boosted_Z28's Avatar
This style tool is the recommended choice for installing a balancer/hub on a crank:
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 8, 2008 | 10:31 PM
Bersaglieri's Avatar
Drive to Fastenal. The manager there in Atlanta is Chuck Kirby, he'll take care of you. Tell him Dustin from Ohio sent you. They stock Grade 8 and even Grade 9 fasteners in fine thread.
-Dustin-
Old Jan 8, 2008 | 10:39 PM
playa7970's Avatar
i was actually recommended to fastenal but i couldnt find it lol what do you know their actually across the street from summit btw thanks again guys i always post on this site before i make a big mistake
Old Jan 9, 2008 | 05:20 PM
playa7970's Avatar
ok so i got the grade 5 rod to work but.... i still have half a inch to go only problem is the crank and and the hub are spinning so i wedged something so that it wouldnt spin... but i cant get to thub to go any further what gives??
Old Jan 14, 2008 | 12:18 PM
xxsaint69x's Avatar
beat it on with a hammer and some wood...works for me every time
Old Jan 14, 2008 | 01:21 PM
But it is hell on the thrust bearing.
HectorM52
Jul 30, 2017 11:46 AM
jb4xx
Feb 2, 2015 10:00 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
1LEThumper
Jul 14, 2003 12:45 PM
