WOT problem
Old Mar 1, 2007 | 05:01 PM
ajlew9428's Avatar
WOT problem
In A4 camaro, when I go WOT, the rpms go up about 1000, then it downshifts, and they go up a little more, then it goes wot. If I floor it, it takes almost 2 seconds for the car to completely downshift, and go. It seems like it stays in gear for a little bit, and tries to go in same gear usually around 15-60 mph. I just had my shiftpoints changed w/ a hypertech or somethin(I didnt do it). Could that have something to do with it, or maybe knock, or possibly tranny problems. Im getting pcmforless soon, and will delete the knock sensor. Any suggestions as to what it is?
Old Mar 1, 2007 | 11:10 PM
oneslowz28's Avatar
Take the hypercrap tune out of it and see if it helps. If it doesnt let us know
Old Mar 1, 2007 | 11:14 PM
mrmint69's Avatar
I would bet the transmission is messed up and maybe its the shift adjustments that did it if your lucky. I think you need the programer to delete the changes.
Old Mar 1, 2007 | 11:15 PM
oneslowz28's Avatar
Yes you will need the programer to take the tune back out. You will need the exact programmer that did the tune too. IIRC
Old Mar 2, 2007 | 12:22 AM
ajlew9428's Avatar
Problem is that im not sure thats what it was. I had the guy that did my install (gears,posi) tune it, and he didnt say specifically what he tuned it with. He just said the only things he tuned were shiftpoints, and speedo. Tranny seems to shift fine, which makes me think its computer related. The guy who tuned it has a 10 second NA impala, so I dont think that he would use that, but he did say I still needed to get my comp. tuned
Old Mar 2, 2007 | 09:06 AM
MEAN LT1's Avatar
I would get the hypertech tune taken out and then see what happends. If that still doesnt work then i would have the tranny looked at. Good luck
Old Mar 5, 2007 | 07:19 PM
ajlew9428's Avatar
update. I had the shiftpoints changed yet again. Now it works great. Thanks for the suggestions
jayblev95
Jan 20, 2015 01:30 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
DETROIT_AREA_00_SS
Aug 12, 2002 11:32 AM
taner
Aug 11, 2002 03:49 PM
smacz28
Aug 6, 2002 01:51 PM
