WOT and High RPM interesting issue
Old Nov 3, 2009 | 11:25 PM
95Blackhawk's Avatar
Hey all,
While road racing, I find I lose power at WOT (100% throttle) and above 5500 RPM with a slight miss. However, if I let off on the gas just a bit (but still in PE mode), then the car seems to gain the power back and lose the slight miss. Further, this issue seems to be a hot issue. Meaning it happens when the car sees a coolant temp above 210 F.
Not sure what could be causing this. Give me some leads.
Thanks,
Ben
Old Nov 4, 2009 | 01:09 AM
LearJet's Avatar
dying opti maybe? Datalog it and see whats going on.
Old Nov 4, 2009 | 05:33 AM
Have you checked the fuel pressure at WOT/max RPM?
Have you considered the possibility of valve float?
Old Nov 4, 2009 | 07:39 AM
No codes. Opti has about 250 miles on it. Granted, high rpm miles. I want to rule everything else out before I go this route again.
BTW, everything is new from battery to plugs: battery, PCM, ICM, coil, plug wires, plugs. OK, plugs have 1K miles on them. Alternator was just rebuilt and have not had a chance to test this item. They said the brushes were worn.
Old Nov 4, 2009 | 07:45 AM
Glad to have your opinions and suggestions on directions to go.
I have not checked pressure because my datalogs show smooth O2 all the way to limit. I know this is not a perfect indicator but I would think there would at least be a 30-50 mV drop at the end if pressure was bad. Thankfully, I CAN check the pressure and so may if this continues. Good idea.
I have not considered valve float because when the car is lower than 200 F and I rev to limit, the car is glass-smooth. Would valve float come into play when I just let off the gas and keep the same RPM but now the car smooths out?
Thanks,
Ben
Old Nov 4, 2009 | 09:04 AM
LearJet's Avatar
could be your coil breaking down when it gets hot. Try adding some space between it and your cylinder head.
Old Nov 4, 2009 | 10:42 AM
That has been done also. Thanks for the idea.
Keep throwing me ideas to try.
Old Nov 5, 2009 | 05:20 PM
Well brand new plug wires with heat shields and one is burnt! I think I found my issue.
A note: Summit Racing's plugs did not hold up to heat at all. With a shield, they did not last as long as my others that were unshielded. Rubber became soft.
HectorM52
Jun 23, 2016 08:42 PM
jayblev95
Jan 20, 2015 01:30 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
97SSdude
Dec 31, 2014 07:43 PM
