WOT & Converter Lock-Up
Old Nov 26, 2007 | 02:38 PM
96ZRDR's Avatar
Is this correct?
Car is a 1993 Trans-AM, 700R4.
Is the converter suppose to lock-up during 2nd during WOT? According to some scans, it stays locked on through the whole ordeal. Is this hurting performance / reliability?
I was understanding that lock-up should only happen while in 3rd gear.
Anyone?
Old Nov 26, 2007 | 02:44 PM
WS Sick's Avatar
Converter lock-up will happen as I understand it at a certain mph in 3rd gear. there is a way to electricly lock it at the ALDL plug with a switch that if your right with it can help times as well.
Old Nov 26, 2007 | 03:13 PM
96ZRDR's Avatar
Ok, thanks. So maybe I should re-phrase the question to .....,should the converter lock-up @ WOT during 2nd gear? I have a feeling this is not right.
Old Nov 26, 2007 | 03:24 PM
marshall93z's Avatar
You sure it's second gear?
Old Nov 26, 2007 | 03:38 PM
96ZRDR's Avatar
Yes sir, using Datamaster I can see the converter lock as soon as it comes out of 1st gear or around 42-45 mph. It stays locked thru 2nd and does not change while in 3rd. Not sure if it is really happening, but I can see when the "TCC Lock" = 1 is commanded.
Old Nov 27, 2007 | 08:30 AM
WS Sick's Avatar
Ok I beleive the 93 since it is basicly a 700R4 locks up on MPH alone anywhere but first gear, and decel.
Old Nov 27, 2007 | 09:07 AM
96ZRDR's Avatar
Yep, if I look at the Tunercat tables, there are thresholds for mph (above 42mph) - it allows for lock-up. Basically this covers all of first gear. Is having the converter locked @ WOT thru 2nd affect performance in any way?
I notice that on the 1-2 upshift, there is some lag in engine response. The shift itself is solid and crisp, but I notice as if the engine is try to match revs (if that makes any sense) once in 2nd gear and eventually catches fire again. It feels like if it had turbo-lag for a second or two after the 1-2 upshift, and then it releases its might.
Not sure how to explain, any thoughts?
2QUIK6
Sep 17, 2016 02:31 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 5, 2015 08:35 AM
jbert55
Aug 3, 2015 05:49 PM
detroitmuscle
Jul 31, 2015 04:21 AM
