Worth it for me to upgrade to 7/16 roller rockers?
Old May 1, 2004 | 03:47 PM
$hawn's Avatar
I plan on buying some comp cams pro magnum roller rockers some time, and it makes sense that if i'm going to roller rockers to go with 7/16 non self aligning, which will also need guide plates and hardened pushrods, which will be a little more than just some 3/8 self aligning. From what I'v understood that non self aligning is that they are more increased stability in the upper rpm's and the 7/16 studs wont flex as much, in my case I dont plan to go any bigger lift cam than around .550-.560, and dont plan to rev past 63-6400. Right now I have the hotcam, and plan to get a pair of build up heads. Would it be in the best interest to go the non self aliging in my case. Thanks for any input.
Old May 1, 2004 | 03:56 PM
OBE1 95Z28's Avatar
I have the CC Pro Mag's and really like them. I've installed several Crane Gold RR's for friend's; performance wise I think the 2 kits will be run the same, I think the aluminum RR's are a bit noisier. You'll probably need a LT4 knock module with either kit. I'd advise you to change your springs to prevent coil bind. My friend didn't (running stock cam) and busted the tips off 2 push rods about 10K miles later.
Old May 1, 2004 | 05:49 PM
$hawn's Avatar
Cant use a knock module on a 93 ecm. Springs are lt4's right now, i'm gonna change those when I get the roller rockers.
Old May 1, 2004 | 05:56 PM
ibanez6rg's Avatar
KMs aren't interchangeable with 93 ECUs.
Might as well make your valvetrain beefy while you can.
DirtyDaveW
Mar 15, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
squinn
Aug 4, 2002 01:06 PM
