car only starts on second try after head swap
Old May 1, 2004 | 09:18 AM
TenaciousZ's Avatar
Question car only starts on second try after head swap
since I finished the head swap, the car will only start on the second try. I try to start it the first try and it won't turn over, try again and it starts up beautifully.
Old May 1, 2004 | 03:37 PM
OBE1 95Z28's Avatar
Check that your fuel pressure is holding (doesn't drop off). You can connect a fuel pressure gauge to the schrader valve fitting.
Old May 1, 2004 | 06:10 PM
TenaciousZ's Avatar
found out the problem, one of my injector o-rings was split in two, replaced it and the problem went away. now the gas smell is gone.
Noenav
Mar 1, 2019 07:38 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
