Won't start only backfire
Old Sep 17, 2005 | 11:04 AM
weinerschizel's Avatar
Ok I put my valve springs and what not all back together and now the engine won't start. It only backfires.
Durring this run of matenance I changed all the valve seals, took the opti off to make sure it was ok, and installed a new fuel pump. Now that it's all back together I can't get the car to start. It only cranks for a few seconds then backfires.
Is it possible my valves are adjusted that poorly? What all can I check before tearing the opti back off.... arg.... to make sure the dowel went in correctly (which i dinked around with to make for sure it went in right so I have a hard time believing its that)... Any ideas?
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
