wont start no spark
Old Sep 19, 2008 | 04:57 PM
Daniel6718's Avatar
wont start no spark
car was driving fine. stopped at a light took off made a turn and it started to spudder for about 30 seconds then died...
first though was gas...either out or fuel pump but both are fine....
we checked the coil according to shoebox and all was fine...
i replaced the coil with another same problem
replaced the pcm same problem
checked and changed out the opti harness
still have the same problem, any other ideas?
Old Sep 19, 2008 | 11:00 PM
Did you check for codes?
Did you verify fuel pump operation with a pressure test?
Old Sep 19, 2008 | 11:26 PM
87bandit's Avatar
what fred said
possible opti failure, I'd say rotor but more common they just shut off when a rotor shatters not a sputter
Noenav
Mar 1, 2019 07:38 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Noenav
Dec 6, 2014 07:35 PM
