Wont rev past 3.5k Fuel problem. I need help!
Re: Wont rev past 3.5k Fuel problem. I need help!
Well if pump is good and filter is good and reg is good then it sounds like you have a blockage in the rail. Wonder if you can blow out the lines with compressed air or you might have to route some alternative fuel lines.
Fuel pressure is supposed to hold around the level it reads with vac line off reg. If it goes to zero you have fuel problem and it can only be pump,filter ,reg or lines .What about blocking inlet screen on pump..?
Garcia5
Jul 7, 2022 06:51 PM
