Wondering What I Would Need To Do My Oil Cooler Delete?
Old Jan 2, 2008 | 11:00 AM
playa7970's Avatar
just curious if i would need anything special or its just a matter of taking it off? thanks
Old Jan 2, 2008 | 11:41 AM
guest74777's Avatar
Guest
Why would you want too?? i think all you would need is something to plug the radiator-water pump and just a oil filter.
Old Jan 2, 2008 | 11:46 AM
playa7970's Avatar
well my cars a 94 and i have a new motor in it but the cooler lines and adapter are old so since im down there already i might as well reduced the amount of problems down the road...coolant leak ect...and ditch it
Old Jan 2, 2008 | 12:05 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I just deleted the oil cooler on my '94. The only things I needed were two bolts to replace two studs holding the oil filter adapter on the block when it's used in conjuction with the oil cooler. There is also a bypass hose that runs from the water pump to the bottom of the radiator. I think it may be possible to simply block off that port in the water pump, which would eliminate the need for that hose, but I'm not absolutely certain about that.
I can post part numbers later today.
Old Jan 3, 2008 | 01:11 AM
jeepbeast's Avatar
I second what bill stated. Just go get two regular bolts to replace the stock one's with a pole on the end and also get a hose from waterpump to radiator and you're done! Part#63492 for the hose. Sorry, i forgot the bolt size to replace the stock bolts.
Old Jan 3, 2008 | 01:20 AM
Stormman's Avatar
I deleted the cooler recently due to coolant line leak and not being able locate a replacement see this post:
https://www.camaroz28.com/forums/sho...d.php?t=560888
Old Jan 3, 2008 | 11:06 AM
BTC's Avatar
BTC
The GM part # for the bolt is 3951644. You will need two of them. You can probably find bolts that will work without going through GM.
The GM part # for the bypass hose appears to be 10197675.
Old Jan 3, 2008 | 11:41 AM
Z-RATED94's Avatar
As stated by some including myself, you will probably gain a slight increase in oil pressure. Plus it's one less part to worry about, as far as collecting debris.
Old Jan 3, 2008 | 04:27 PM
marshall93z's Avatar
I took a dremel tool and cut the top off my bolts. Worked fine.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
alex5366
Mar 8, 2015 11:32 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
97 RedSS
Jun 10, 2003 07:58 PM
