Wiring up CSI water pump?
Old May 14, 2005 | 08:34 PM
Red on Red WS6's Avatar
I put a CSI water pump in and I was wondering what relay I should buy, type and part number would be great. I also need a relay to wire up a manual fan switch could I just use the same type? On a side note I was wondering if there is a way to wire up a warning light when the water temp gets to a certain point? This is my goal, my car never gets above 190 deg. so if I could wire somthing up where a light goes off at 195 deg I would know that the more than likley the water pump has failed. By the way I want this in addition to the light when it loses power.
Old May 15, 2005 | 08:26 AM
slopokrodrigez's Avatar
Re: Wiring up CSI water pump?
Try this diagram. http://www.cardomain.com/memberpage/518431/3
Old May 15, 2005 | 12:27 PM
Originally Posted by slopokrodrigez
do you remember what relays you used?
Old May 15, 2005 | 12:30 PM
Beyonce Knowles's Avatar
I just "borrowed" my old AIR pump relay.
Old May 15, 2005 | 02:02 PM
97WS6SCharged's Avatar
Most people just use a 30 amp relay.
Old May 16, 2005 | 02:18 PM
Yeah the reason I was having so much trouble finding the relay is because I was going to the auto store. I went to radio shack and they had the exact ones I needed. Thanks guy's
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
pologreen97z
Dec 2, 2014 10:42 AM
