Wiring issues???
Old Aug 17, 2004 | 08:14 PM
Heatmaker's Avatar
Advanced Member
Wiring issues???
My Factory wiring harness was cut and I have to start from Sctrach...
I have a
Dimmer Wire
Illumination Wire
Memory Wire
Ignition/acc wire
What should I connect the wires to in the fuse panel on the side of the dash? I'm clueless on this radio stuff...???
Old Aug 17, 2004 | 08:33 PM
Dave89IROC's Avatar
Re: Wiring issues???
are you wiring a radio?
Old Aug 17, 2004 | 11:44 PM
Heatmaker's Avatar
Advanced Member
Hi,
I'm wiring in a stock replacement wiring harness... but I want to run fresh new wires from the fuse panel.... To keep things simple...
Old Aug 17, 2004 | 11:52 PM
If you have a hacked up harness. you need a manual for whatever year car it is that you are working on.
mattstrike
Mar 12, 2015 10:12 PM
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 5, 2015 07:14 PM
