Where ca I get the elbow that goes between the MAF sensor and intake plenum?
Old Aug 17, 2004 | 11:25 PM
joebeemish's Avatar
I added an electric wather pump and it sticks out further than the original water pump. My mechanic cut the 18" nose off the elbow that sticks down from the elbow and taped it up because it did not fit anymore. I have seen an aluminum elbow without the nose. Does anybody know where I can get a replacement? Will the '95 corvette stock elbow fit? I think it does not have that long extension on it. By the way, what is that thing for?
Thanks.
Old Aug 17, 2004 | 11:53 PM
n2ceptor's Avatar
Re: Where ca I get the elbow that goes between the MAF sensor and intake plenum?
Are you talking about the silencer that was on the bottom of the elbow?? If so, you can remove it and place the bottom part of a shampoo bottle( ie: Pert) to close the hole.... If you want an Aluminum one check at Summit or Jegs... They have them..
Old Aug 17, 2004 | 11:55 PM
...or you can buy a factory 1LE elbow that does not have the silencer hanging down. ~$45 from Jason or Dal (search).
Old Aug 17, 2004 | 11:57 PM
joebeemish's Avatar
Sorry for my ignorance, what is 1LE? And is there a better part name than elbow for search purposes? How does the silencer work?
Old Aug 18, 2004 | 12:14 AM
1LE is an RPO code used for a special package on the f-bodies. The 1LE elbow did not have the silencer. p/n 25147187 for 1995-1997 cars. The bottom is sealed up. How does the silencer work? Not really sure, but a lot of the GM cars have them in one shape or another.
n2ceptor's Avatar
1LE is a performance option..... The silencer quiets the noise of the air going into the engine...
Old Aug 18, 2004 | 12:32 AM
joebeemish's Avatar
Shoebox - thanks. good pictures. My searches using some keywords you provided found some things i didn't know, like
http://www.gmpartsdirect.com/
Looks like a good place to get parts.
Old Aug 18, 2004 | 12:36 AM
I hoped you would search for Dal or Jason. Consistently better shipping rates.
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
or
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: parts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Old Aug 18, 2004 | 12:37 AM
joebeemish's Avatar
That's how I found parts direct. I will call Jason or Hal. I found their numbers also.
Old Aug 18, 2004 | 12:39 AM
That's Dal , short for Dallas.
Old Aug 18, 2004 | 12:42 AM
joebeemish's Avatar
Ok, I'll tell them you sicked me on them...
Old Aug 18, 2004 | 12:55 AM
Blue89Bird's Avatar
if he got 1% of all sales hes got them, he'd be a rich rich rich man
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
pete53
Dec 9, 2014 07:31 AM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
