Wireing Headache
Old Aug 31, 2006 | 08:42 AM
Badley's Avatar
Wireing Headache
I am wanting to eliminate some of the stuff from my wireing harness. Stuff such as a the EGR valve, the wind shield cleaner motor, and stuff like that. Can I just cut the wires and move on.. or will that mess up the computer. Thanks.
Badley
Old Aug 31, 2006 | 09:04 AM
Re: Wireing Headache
Body parts like the windshield wiper or washer pump have nothing to do with the PCM, so they will not affect it. The fact that you have deleted the EGR (and possibly other items) will potentially set a code in the PCM, so hopefully you plan to have those codes programmed out. That leaves you with a lot of unused wires that can be removed if you want to. Just make sure not of them is bare and shorting against anything.
Might want to add a "signature" with basic info about your car.... year, tranny type, major mods.
Old Aug 31, 2006 | 09:39 PM
Badley's Avatar
Thanks ill work on the sig.. I have a 68 camaro, droping in a LT1 from a 96 Firebird, 4l60E trany, ford nine inch rear.
Old Sep 1, 2006 | 11:28 PM
Badley's Avatar
So its cool to cut out the stuff i dont think i need?
Old Sep 2, 2006 | 09:45 AM
LT1_383's Avatar
No. It's cool to cut out the stuff you know you don't need though
Old Sep 6, 2006 | 08:46 AM
Badley's Avatar
gotcha
timmy39120
May 2, 2015 05:12 PM
surreybrad
Apr 22, 2015 06:40 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
