Windage tray with ARP Main Studs
Old Jun 22, 2003 | 12:06 AM
thewinner's Avatar
What windage tray you guys using with the ARP main studs? There are too many studs sticking up for the stock one to fit. and some holes dont line up.
Any ideas?
Thanks!
Old Jun 22, 2003 | 12:59 AM
Mindgame's Avatar
If memory serves me correctly, you need to use the solid windage tray. You can get it from any GM parts house.... Jim Pace, Sallee and so on.
Check out page 3 of this .pdf file, http://www.s-series.org/htm/tech/GMP...ts/082-086.pdf
That flat windage tray shown there... nothing too eciting about it... is the one you need.
Damn, I saw an online article a while back where they used that same tray on an LT1..... I'll try to find it real quick.
edit: Here's the article, http://www.corvettefever.com/howto/36501/
Just make sure to check with the GM guys to see if that is really the one you need. This is just stuff I remember reading so take it as that.... no actual experience here. My pan has the tray built in.
Good luck.
-Mindgame
Old Jun 22, 2003 | 01:15 AM
thewinner's Avatar
damn, thanks man!
did they use the first or second one on page 3? cause the second one looks exactly like the stock one... ill take some pics tuesday of where the bolts hit and stuff.
mindgame, you think i made out good on the shortblock? forged 4340 eagle crank/forged 4340 hbeam rods/srp pistons/machine work/balancing/mill heads and fix guides / all the small stuff, arp main studs
all for 2864
Old Jun 22, 2003 | 01:18 AM
thewinner's Avatar
http://www.corvettefever.com/corvett...mage_small.jpg
What is that gasket called? i think i forgot to get that lol
Old Jun 22, 2003 | 08:25 PM
arnie's Avatar
Re: Windage tray with ARP Main Studs
Any ideas?
Thanks!
The oem tray takes 3 studs. It's ok to cut off those you don't need. Sure beats not having enuf, right? Tray used will depend on the pan used.
Old Jun 22, 2003 | 08:41 PM
akafred's Avatar
studs
you dont need to cut em just put the studs where they are needed and the extra long ones where they are out of the way i think there is 5 i put one behind my oil pump and one infront of the tray they will clear the oil pan just fine
Old Jun 22, 2003 | 10:11 PM
arnie's Avatar
Like t*ts on a boar hog, if not needed, they are gone! Didn't state you had to, just that it is ok.
Old Jun 22, 2003 | 10:31 PM
96z's Avatar
96z
That gasket usually comes with the rear main seal and housing....mine did atleast.
13qtr
Oct 28, 2016 08:11 PM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ericksd
Jan 20, 2016 06:07 PM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
