Will vert. mount looms work with existing wires?
Old Jun 18, 2003 | 02:10 PM
107's Avatar
107
Im about to install some LT headers and I already have a set of Taylor 8mm wires installed(I purchased the LT1 pre-cut set a while back)-
Everyone says to buy the OVC set but I hate buying a whole new set of wires that are the same thing I have except a little longer... I was looking on thunderracing and they have the vertical mount looms that don't look like the require as much lengh as the top mounts and would serve the same purpose- does anyone know if these would work with my existing wires?
Thanks a lot!
-107
Old Jun 18, 2003 | 05:39 PM
revtime's Avatar
You will probably still need custom length wires.
I have MSD super conductors and I routed them very carefully and even ran the last 2 on drivers side up and over the valve cover cause I could not find a way to mount them under without em frying. Personally I think regular wire kits will work with headers you just have to route em right and keep a healthy dose of zip ties on hand when you do it.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
