Will this valvetrain stuff work together
Hey whats up I have the following parts and was wondering if you guys could make sure for me that they will work together.
CC-787-16 Comp Cams Retainer For Non-LS1 918 Spring
CC-26918-16 Comp Cams 918 LS1 Valve Springs 130 @
1.800, 318 @1.200
CC-601-16 11/32 Single Groove Lock Set of 16
I was informed that these parts would work out nicely for my application so can you guys confirm that.
1.800, 318 @1.200
Re: Will this valvetrain stuff work together
I recently installed the 26918 springs, and used the following part numbers:
I'm not sure if the ones you listed will work or not. I know there are offset retainers and locks available (to adjust install height); The ones I used were not the offset ones.
Thomas.
- Comp Cams 918 Springs --- 26918-16
- 10* Comp Cams Steel retainers --- 759-16
- 10* Comp Cams Super Locks --- 611-16
- Comp Cams Shim Kit --- 7453
Thomas.
