will timing GEARS fit behind a 95 timing cover.
Old Mar 9, 2005 | 04:20 PM
TransAm396's Avatar
Ok i know that with an electric waterpump your options open up as to which timing chain you can use. I was wondering if the timing GEARS would fit behind the 95 opti cover so that i can use them instead of a chain. The KM will be desensitized so thats not a problem..just wondering if it would fit.-Mark
Old Mar 9, 2005 | 05:24 PM
Kataklysm's Avatar
Re: will timing GEARS fit behind a 95 timing cover.
I'm doubting it, I'm sure someone would have mentioned something about a kit by now. Just get a heavy duty chain and oversized sproket.
Old Mar 9, 2005 | 05:26 PM
TransAm396's Avatar
well LT1s are different cuz of the waterpump drive..but since im not using that..i can put whatever in there..just wondering if space wise if the gears would hit the sides
Old Mar 9, 2005 | 05:30 PM
dover179's Avatar
If I remember correctly, it will fit, you just need to do some grinding on the timing cover. I'm sure somebody will correct me if I'm wrong.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jlo
Feb 3, 2015 09:41 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
