Will thicker gear fluids allow for quieter operation?
Old Jun 10, 2003 | 01:57 PM
JTS95TA's Avatar
My Motive 4.10 gears are a bit noisy on deceleration and its getting kind of annoying. They are perfectly quiet at constant speed and acceleration but once I let off the gas they make some noise. Someone at a local shop said to try a heavy duty gear oil like for trucks or something. Not sure exactly what grade he said but will this infact quiet the gears down a little by using a different type of fluid? Right now I am running the Mobile 1 75w90 synthetic fluid and the GM additive.
Old Jun 10, 2003 | 02:59 PM
Dave C. '97 Z28's Avatar
Yes...
I used to run 85w-140 when I had my 4.10's to keep them quiet.
-Dave C. '97 Z28
PS: Make sure you still use the limited slip additive.
Old Jun 10, 2003 | 03:24 PM
IrocManiac's Avatar
Originally posted by Dave C. '97 Z28
Yes...
-Dave C. '97 Z28
Using the wrong additive can be either terrible for the gears or hard on your ears or both...friend of mine went to get a fluid change and they put in the wrong fluid and he brought it over cause it was making a terrible noise...sure enough wrong fluid...no damage done though...
Old Jun 10, 2003 | 04:32 PM
JTS95TA's Avatar
IrocManiac,
I am referring to the actual gear oil itself NOT the additive as no matter what fluid I use I would still use the GM limited slip additive. Maybe im misunderstanding you but any type of gear fluid should work just make sure in our cars we use the GM additive. Is this what your saying or were you talking about the gear fluid itself?
PCLZ28
Dec 24, 2015 05:19 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
VF-124
Mar 16, 2015 08:14 PM
