Will these pushrods work for me?
Old 04-23-2009, 06:37 AM
madhatter's Avatar
I just picked up NIB Comp Magnum 1 piece 5/16 7608-16 pushrods for $60! But now I am wondering if they will work with Comp Pro Mag 1.6 NSA RRs. I have the guideplates, studs, 918s etc.
Help?
Sean
madhatter is offline
Old 04-23-2009, 12:34 PM
Stl94LT1's Avatar
Are they hardened pushrods, and what length?
Stl94LT1 is offline
Old 04-23-2009, 03:54 PM
truedualws6's Avatar
http://store.summitracing.com/partde...rt=CCA-7608-16
truedualws6 is offline
Old 04-23-2009, 04:01 PM
94zgreenmachine's Avatar
If you haven't done any head work or had the deck blocked you should be fine. Milling the head, thinner head gaskets and decking the block will surely affect the pushrod length. 7.2 is the stock length. If it really bothers you, put it in and use a weak spring to see how the rocker rides on the valve tip. You'll want a nice narrow patch on the valve like this:
94zgreenmachine is offline
Old 04-28-2009, 01:33 AM
madhatter's Avatar
I am more worried about material than anything. Heads have never been off.
Old 04-28-2009, 07:17 AM
Moderator
rskrause's Avatar
They are hardened, if that's what you mean.
Rich
rskrause is offline
Old 04-28-2009, 07:32 AM
bw_hunter's Avatar
Those will work with guide plates, no problem. Why are you changing from the stoockers?
bw_hunter is offline
Old 04-28-2009, 02:48 PM
madhatter's Avatar
Thanks for the help Rich.
I am replacing everything else in the valvetrain when I do the RRs. And I will need them when I do the cam in a few months.
HectorM52
07-30-2017 11:46 AM
Noer
02-28-2015 11:29 AM
armedtrigger
02-24-2015 08:30 PM
Roadie
02-16-2015 10:34 AM
07-04-2005 05:00 PM
Quick Reply: Will these pushrods work for me?
