Will these header bolts work?
Old Mar 20, 2006 | 09:30 PM
Blackthunder50's Avatar
I want to use as many threads as i can so I dont stip the aluminum heads. I have BBk headers which have a thick 3/8" flange. I want to use a 1.25" header bolts so I can use as strentgh as possible. Will these work or will they hit the end of the bolt holes?
Old Mar 20, 2006 | 09:35 PM
2QUIK6's Avatar
Re: Will these header bolts work?
On mine I could not see anything longer than 3/4" after going thru the header flange without bottoming out, I'd think you could use anything longer than 1", maybe an 1 1/8" total... Just screw one of your original manifold bolts in without the spacer on it and see how far it will go in. With the spacer on them, each bolt should be 1" without going thru the manifold yet.
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
