going to drop pan...need some input.
Old Mar 20, 2006 | 12:44 PM
crAzy95z28's Avatar
well since i dont have a hoist can i just jack the car up from the crankshaft hub?
ive heard its a bad idea, but its the only way i can do it.
any opinions would be great.
thanks Randy
Old Mar 20, 2006 | 12:56 PM
crAzy95z28's Avatar
Re: going to drop pan...need some input.
qeustion. Do i need to buy a stock replacement or a High Volume oil pump??
Old Mar 20, 2006 | 12:59 PM
Javier97Z28's Avatar
Moderator
You could always just rent a hoist
Old Mar 20, 2006 | 01:07 PM
OutsiderIROC-Z's Avatar
Is that a serious question????
Old Mar 20, 2006 | 01:09 PM
jsetzer's Avatar
I would suggest a board under the transmission. A hoist would be better if you could get one.
Old Mar 20, 2006 | 01:14 PM
CamaroBoy96Z28's Avatar
You can support the motor from the trans and hub. The hoist would in fact be the best option though. I jacked the motor up from the crank hub but because I was in the same situation but use a hoist if possible.
Old Mar 20, 2006 | 01:28 PM
crAzy95z28's Avatar
i understand the hoist is better option, but i dont have one. And btw the crankshaft is forged and stronger than that steel one. But this is the only thing i can do.
So just jack it up from the hub and possibly from the tranny useing a 2x4 for the tranny pan?
Old Mar 20, 2006 | 01:31 PM
jsetzer's Avatar
I don't know what the auto tranny looks like (or even if you have one) but the t56 is pretty beefy on the bottom. I use that when I installed my headers and had to lower the kmember to get them in.
Old Mar 20, 2006 | 02:44 PM
ajschult's Avatar
rent a hoist.
Old Mar 20, 2006 | 03:03 PM
Moderator
As has been mentioned twice now, you can rent a hoist from a tool rental store for a weekend to do this.
Old Mar 20, 2006 | 04:13 PM
1redTA's Avatar
you can lift it using the tranny as a lift point. I don't think I would use the hub and risk bending it. It is a pita but better than pulling the whole engine any day
Old Mar 20, 2006 | 05:09 PM
crAzy95z28's Avatar
so just put a 2x4 under the jack, and jack up the tranny, but undo the tranny mount 1st right?
Old Mar 20, 2006 | 05:14 PM
MeanGreen97Z's Avatar
I see a disaster coming......
Old Mar 20, 2006 | 05:17 PM
Josh-'04 GTO's Avatar
I agree. It would be a cold day in hell before I lift up my motor by jacking up the crankshaft hub!
Old Mar 20, 2006 | 05:18 PM
3gc's Avatar
3gc
Definately rent a hoist. I pulled my pan twice last week, with the hoist it's only a two hour job start to finish. I don't think you risk bending the crank, but you certainly put an undo strain on the bearings. I wouldn't feel very safe with the whole weight of the engine resting on the hub, i'd be worrying about it falling off. I'm with everyone else here, go spend the $30 and rent an engine hoist from the local tool rental place, or find a friend with one.
