Will a summit timing chain work in a 95 lt1?
I have a 94 lt1 camaro that I'm putting a 95 cover and opti on,my problem is I have to change the cam gear,so now I think I might as well change the whole set since I have a le2 setup.Will the summit chains(g6600-
g6601) work/ I dont want to get the cloyes if I dont have to? or if anyone have any other choices?
If your talking about the summit chain for a regular roller motor the $40 one, it will but you have to grind the cover. I used a jegs brand 9 way adjustable set for like 70 and had no problems. but if you want that water pump drive those won't work.
