Will the stock cat kill hp?
Old Dec 24, 2003 | 12:17 AM
Montezuma's Avatar
I'm about to slap on the new longtubes tommorow. Since its a convertible i'd like to avoid the smelll and excessively loud sound of a catless setup. Mods are Pacesetter longtubes, offroad Y pipe, Magnaflow, ( I plan on jerry rigging it to all fit together).
Will I lose a lot of hp
Old Dec 24, 2003 | 12:25 AM
S.J.S.'s Avatar
Any cat will cut HP, especially the stock ones. You just have to weigh your options and decide what you want. More HP or a loud smeeling convertible.
Old Dec 24, 2003 | 12:30 AM
Montezuma's Avatar
5hp? 10hp? less - more
Old Dec 24, 2003 | 06:06 AM
rskrause's Avatar
Moderator
Very little, if any, hp loss from the cat on a basically stock motor. The more serious the mods, the more important it is to eliminate exhaust restrictions. FWIW, I am making >800rwhp through cats, so I guess you know my preferences.
Rich Krause
Old Dec 24, 2003 | 08:18 AM
gamecockfan04's Avatar
Loose the cat, or at least get a high flow cat. You can get a Carsound High Flow Cat off ebay brand new for $35, and Ive heard nothing but good things about them.
Old Dec 24, 2003 | 08:03 PM
dogboy's Avatar
Carsound high flow cat . Would that be the 3 " for the single cat 94? also with or without air tube? What does the air tube do??
Old Dec 24, 2003 | 11:35 PM
94blackz14.2's Avatar
The air tube just runs to your airpump. The purpose of the air system is to heat up your cats more quickly and make it more efficient at cleaning the exhaust...at least that is what I think I read. Down here in Florida there aren't emission issues to deal with so I would say goodbye to your cats and airpump. My car sounds so much better since I removed my cat.
Old Dec 25, 2003 | 01:51 AM
94formulabz's Avatar
Short answer: without the air tube.
3 way catalytic converters come in two variations, with and without air injection. I believe 3rd gens had the version with constant air injection. Basically there are two honeycombs in the cat and an air pump that runs continuously to inject extra air into the system before the second honeycomb of catalyst.
We have 3 way converters without air injection. Yes, we do have an air pump, confused yet? Our air pump only runs at startup to help warm the cat(s). It pumps air into the manifolds or headers, NOT directly into the cat like the 3way+air that i mentioned above.
-brent
canbaufo
May 25, 2015 12:01 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
