Will someone help me post a DYNO graph for XE224/230?
Old Jul 11, 2003 | 10:27 AM
  #16
RealQuick's Avatar
Also, ropping back down to 4100rpm isnt a bad thing with that fat torque curve! You'll be right in the meat of it!
Old Jul 11, 2003 | 10:41 AM
  #17
BBB's Avatar
BBB
Originally posted by BradZ28
Shifting at 6000-6100 is exactly what I wanted With 3.42 gears and a M6 I want to end the 1/4 at the top of 3rd (appx 110-115 mph trap) not bad for a N/A 350.
Brad
You will be in 4th gear at 110-115 with a 3.42 and 26" tires. I have to kick mine up at about 100-102mph. At 155 you should be half way through 4th.
BBB
Old Jul 11, 2003 | 10:53 AM
  #18
RealQuick's Avatar
BBB
Your right about 100-102mph end of 3rd into the 4th shift, but he will be in 5th gear to get up to 155mph. With my 3.73's (obviously my rpms will be slightly higher) I was at 5000-5200rpm @ 140mph in 5th gear!
Old Jul 11, 2003 | 12:01 PM
  #19
Fastbird93's Avatar
This should help: Gear Calculator
Old Jul 11, 2003 | 12:20 PM
  #20
94formulabz's Avatar
Originally posted by RealQuick
You dont want to shift at 6500rpm with the 224 cam based on that dyno graph. I run faster when shifting about 200rpm passed peak hp. At 6500rpm your lucky to have 250rwhp the way it fell off. I wouldnt shift below 350rwhp, but even that is spinning way past peak. Peak looks to be at 5750rpm, so I would realy shift at 6k-6.1k!
Your are right if it actually dropped off like that, but i think that was someone lifting their foot or a revlimiter.
Old Jul 11, 2003 | 12:33 PM
  #21
Your right, there is still a lot of power there, but if we are talking about optimizing shifts we need to look at the area under the curve of the HP graph. Example you have 317 footpounds at 2100 rpms, but yoru only making 126 HP. 126 HP= not the best acceleration. Ideally you want your HP the exact same before and after the shift because that will maximize the work done.
If there is something like weak valve springs holding back the power up there than i can agree with the 6200 shift. But if we are just talking about the physics of the cam for optimum power it's closer to a 6500 rpm shift.
Old Jul 11, 2003 | 01:13 PM
  #22
BradZ28's Avatar
That gear calculator is sweet. Thanx for setting me straight. I was worried before this post that the 224/230 may not make power where I wanted it to but now I'm feeling reassured.
Going sideways into 3rd=
Get that DYNO up Fastbird93!!!!!
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
TitoPR221
May 26, 2015 12:20 AM
BLK1997Z28
May 7, 2015 03:01 PM
Russ95Z28
Apr 23, 2015 01:55 PM
