Will this setup work to connect to my computer?
Old Feb 20, 2004 | 10:33 PM
warwickbass's Avatar
It's a '95 Z28. Will the EZ Read 2000 with the Replacement GM Special OBD-II cable correctly hook up to the connector? If not, what do I need? Thanks.
http://www.autoxray.com/products.aspx?sub=readers
Old Feb 20, 2004 | 10:42 PM
Yes, it will work and comes with multiple cables, including the one you need. But unless you need to be able to pull codes from all different manufacturers of cars, why buy that one? It also is only a code reader and not a scanner. The reason it is so expensive is because it comes with all those cables and can do OBD-I and II.
I think I gave you a recommendation once before.
Old Feb 20, 2004 | 10:48 PM
Yeah, I could've swore it was this one. Which one exactly do I need? I'm lost, man.
Old Feb 20, 2004 | 10:59 PM
Depends on what you want to do. Do you want to only pull codes or be able to scan, too (better choice, IMO)?
http://web.camaross.com/forums/showt...hreadid=223386
To scan on a 1995:
http://www.autoxray.com/products.aspx?sub=scanners&id=4
and
http://www.autoxray.com/products.aspx?sub=cables&id=11
Old Feb 20, 2004 | 11:04 PM
To scan on a 1995:
and
What's the difference? I have the Haynes manual with all the trouble code definitions and all.
Old Feb 20, 2004 | 11:17 PM
The difference is that a code reader only reads codes and nothing more. A scanner will allow you to look at engine sensor readings and diagnose trouble. IMO, I would not waste my money on just a code reader, but that is just me.
Old Feb 21, 2004 | 12:30 AM
I guess I'll buy the GM OBD-I Scanner along with the REPLACEMENT GM SPECIAL OBD-II CABLE. I appreciate the help.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
