Will run good for about 15 minutes
Old May 18, 2004 | 10:09 AM
  #16
SATANAZ666's Avatar
SORRY TO Hear the O2 swap didnt work.....Keep us posted as to what solves your problem.
Good luck dude
Old May 18, 2004 | 09:28 PM
  #17
ibanez6rg's Avatar
Any other ideas?
Old May 18, 2004 | 11:38 PM
  #18
fozziez28's Avatar
i had a similiar problem, car would heat up and idle would be $hitty and it felt like major cam surge, died a couple times. I solved it by doing two things, cleaned the maf with alcohol swabbs, and installed a 160 stat to keep it in lower operating temps. reprogram the fan temps as well and see if it helps. t-stat is only 20 bucks. worth a try. -MIchael
Old May 19, 2004 | 01:46 AM
  #19
CoUnTryMuZiCZ28's Avatar
hmm... Mine was doing that, my problem was the IAT, it would cut out and hesitate.. one of my wires were split... It never crossed my mind that a little thing like that could do it. if not that, maybe your coil wire. might be leaning on the water pump.. which would explain it not starting, but if you replced the ICM im sure you check the wire. Do any lights come on when this happens?
Old May 22, 2004 | 09:25 AM
  #20
ibanez6rg's Avatar
Also, knock will go up the longer it runs. Starts out at 0.0 on a cold start-up, but will slowly get up to 5-6 while driving.
Old Jul 19, 2004 | 11:33 PM
  #21
ibanez6rg's Avatar
Re: Will run good for about 15 minutes
Just filling you guys in. Was the elec. harness on the Opti. But, I guess I have a completely new ignition from head to toe now.
DirtyDaveW
Dec 1, 2016 05:37 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
HCz28
Jan 11, 2015 11:21 AM
skittlez87
Dec 29, 2014 03:23 PM
