Will this oil level sensor work?
Old Jun 9, 2004 | 02:58 PM
SplitFire's Avatar
I ordered a new oil level sensor since oil was leaking out of mine, but the part # the guy at the chevy center gave me is 12579983. It has the same shape as the original part, but is made of plastic instead.
I told the guy that it didn't look the same and he told me he ordered one for a 3.8 instead of 5.7 but checked, and said that the part #'s were the same. Does anyone know if it will work?
Prices on gmpartsdirect for the two different #'s are way different. The one listed for the 5.7 is like $45 and the one I got was only $18.
Thanks for any help.
Old Jun 9, 2004 | 05:45 PM
jkipp84's Avatar
I had to replace mine a few months back, I got it from Jason Cromer and it was around $40. It doesn't sound like you've got the correct sensor to me.
Old Jun 9, 2004 | 06:24 PM
According to gmpartsdirect, the number changed from 24507190 to 12579985
Old Jun 9, 2004 | 10:48 PM
SplitFire's Avatar
Thanks for the replies. I guess I'll take it back tomorrow and have the guy look up these other part numbers.
Old Jun 10, 2004 | 12:11 AM
Lt1t56's Avatar
I replaced my low oil lever sensor last week due to a leak, the original one is made out of metal (where the wrench contacts it) the new one is totally plastic.
Old Jun 10, 2004 | 12:13 AM
SplitFire's Avatar
Do you happen to know what the part # was for the one you bought? The one you put in sounds just like mine. Made completely of plastic.
Old Jun 10, 2004 | 12:25 AM
Lt1t56's Avatar
Like Shoebox said, the part # has changed from 2450719 to 1257995. I was doing an oil change when I noticed mine leaking so I wasnt patient enough to wait for one to come in the mail so I went to the stealership and they bent me over for $45.00 + tax. part #12579985
Old Jun 10, 2004 | 12:46 AM
SplitFire's Avatar
Thanks, I was just wanting to see if your sensor had the same part # as the one the guy gave me today since they were both made of plastic.
Old Jun 10, 2004 | 11:50 AM
SplitFire's Avatar
I went back to the chevy center today, and had the guy type in the part #'s that shoebox and lt1t56 gave me. When he did, he got 3 pages of oil level sensors, none of which were for the camaro. He typed in the part # again for the sensor he sold me, and it came up for a camaro. He also showed me the diagram just to make sure it was the right part.
I'm going to try it out, and I'll post a reply if it doesn't work just in case someone has the same problem. If it does work, it will have saved me about $25.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
