will new valve seals
Old Mar 27, 2007 | 06:47 AM
ZL1modified's Avatar
increase your oil pressure...
i did a spring swap and now my oil pressure is well past 80... it stays between 40 and 60 with normal driving but when i "get on it" the pressure goes well over 80...
i changed the oil and filter and i still have the problem...
i did notice metal shavings on the drain plug...(nothing large probably shavings from when my old stock rocker arm fell off)
i put a mechanical guage on it and it still reads high...
before the new seals my pressure would only go to 75-80...the only thing i can think of is that the new valve seals increased the pressure from what it was before...
Old Mar 27, 2007 | 06:53 AM
mdacton's Avatar
No they will not
Old Mar 27, 2007 | 07:27 AM
is there a way to flush the oil system...
i guess i should ask... will this hurt my engine?
Old Mar 27, 2007 | 09:19 AM
OBE1 95Z28's Avatar
What weight oil are you using?
Old Mar 27, 2007 | 09:44 AM
i was using 10w30 but then i switched to mobile 1, 5w20... the pressure came down a little at idle but had no affects at high rpm's...
Old Mar 27, 2007 | 02:55 PM
mdacton's Avatar
I don't think its anything to worry about
Old Mar 27, 2007 | 04:09 PM
blackztpi's Avatar
2nd that
94Form
Jul 17, 2015 10:56 PM
GT what?
Jul 14, 2015 10:17 PM
Catmaigne
Jul 14, 2015 05:17 PM
camaro02DK
Jul 5, 2015 09:24 AM
