will i run into problems?
Old Oct 4, 2008 | 01:41 PM
sn8ke eatr's Avatar
with 12:1 compression and a comp cc305? i know its a small cam and i was a little concerned the cr is too high. think ill have to mix in some race gas? or play with timing? any inputs appreciated
Old Oct 10, 2008 | 06:03 PM
sn8ke eatr's Avatar
come on... no one?
Old Oct 10, 2008 | 06:22 PM
Have you calculated the dynamic compression ratio (DCR)? That's what will determine the engine's octane requirements, moreso than the static compression ratio. If you are under 9:1 DCR you will probably be OK on 93-octane pump gas. Over that and you may have a problem.
You'll need to find an online DCR calculator, and you will need to have the details of the cam event timing.
Old Oct 10, 2008 | 06:34 PM
firstlast's Avatar
not true. i have an 11:5:1 compression ratio and i run pump gas no problem. 12:1 would make me nervous
Old Oct 10, 2008 | 07:28 PM
What is your DCR?
Old Oct 10, 2008 | 08:53 PM
markclrks's Avatar
united engine and machine co. has one on there site
Old Oct 10, 2008 | 09:52 PM
firstlast's Avatar
very close to my static. it is above 11:1 for sure. i
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
97SSdude
Dec 31, 2014 07:43 PM
