will i make it...?
Old Jun 7, 2005 | 02:18 PM
DiabloGT's Avatar
will i make it...?
if i install pacesetter lts + y pipe, highflow cat, slp lm, ngkt tr55 spark plugs and otvc spark plug wires all in one saturday? is that enough time?
thanks
Old Jun 7, 2005 | 02:20 PM
Kurt Crosbie's Avatar
Re: will i make it...?
yes, but have all your tools ready and read up on each procedure before you get into it. things happen. you may find after you get started that you are missing tools you need.
Old Jun 7, 2005 | 02:44 PM
1SlowFormula's Avatar
Also how are you going to mount the cat, is it slip fit and are you going to need to cut your exhaust to get it to fit somewhere, make sure where you cut the exhaust is the same diameter as the cat your using...
Those are just a few things for you to think about before starting.. And like Kurt said above get everything ready and be sure you know what you will be doing and in what order.. It always helps to plan ahead, but sometime **** happens and things come up..
You should be able to do it in one day but don't rush yourself, if you think you are cutting corners don't they seem to bight you in the a$$ later and it is worth taking a few extra minutes to do it right.
Old Jun 7, 2005 | 03:06 PM
DiabloGT's Avatar
ya all around there 3" the headers, exhaust, and the cat on both sides...
Old Jun 7, 2005 | 03:17 PM
But my question still stands, is the cat slip fit so it actually goes over the 3" pipe or are they both exactly 3", you may want to check that and take it out to be widened/streched a little before you try the install.. Just test fit all the parts before you try to put it in the car.
Old Jun 7, 2005 | 03:23 PM
BUBBA's Avatar
No. Do not plan on doing all that in one day. JMHO
Old Jun 7, 2005 | 04:08 PM
DiabloGT's Avatar
why not??? i just wanna get it all done with lol, oh and the cat fits right over the 3" inlet pipes, so there should be no problems
Old Jun 7, 2005 | 04:10 PM
lt11997's Avatar
I would expect 1.5 days to do this, you never know if something will go wrong or won't fit right. You could spend a couple of hours just trying to get a header in and the old exhaust won't be nice to you.
grabbem88
Mar 18, 2015 01:25 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
ScottZ
Mar 3, 2004 01:34 PM
