Will I have PTVC Trouble with my Heads Decked .030 a .039 Gasket and this cam?
Old Aug 22, 2003 | 11:10 AM
OBDIICamaro's Avatar
I have just got my heads decked .030, I am running I havent decided yet either the GM .029 Gasket or the Felpro 1074 .039 Gasket. I also have 1.6 Rockers, am I going to run into Piston to Vavle Clearence?
CCA-224-236-14
Dur@.050 224-236 | Lift .503-.521 | LSA 114 | RPM Range 2000-6200
Old Aug 22, 2003 | 12:09 PM
llafro's Avatar
I am running heads that were shaved 0.030" and the 0.029" Impala head gaskets on a stock bottom end. I have a more lift than you (230/236-112 0.544"/0.555" lift) and its not a problem. There are people here running more lift than me without a problem. If you are worried about it, then verify it with modeling clay. There are guides on how to do it. Basically you put a thin layer of modeling clay on top of the piston and turn the engine over to see what kind of interference you will have.
BRAD
Old Aug 22, 2003 | 12:12 PM
Oh I know how to clay its just the lazyness factor Come on what do you think Cz28 is for
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
