Will I be able to use stock FI for rebuilt motor?
Old Sep 20, 2003 | 05:24 PM
Kurt Crosbie's Avatar
I found an LT1 block for sale with a seized piston. It has no heads. I know I'm not going to need the heads, so they don't matter (since I'm going to need the AFR215's to be pushing 500hp). But, I don't want to have to pay 2000 bucks for a fuel injection system when I'm done rebuilding the motor when I could have just bought a motor with everything on it.
Old Sep 20, 2003 | 11:59 PM
LPEdave's Avatar
Well, you're definitely going to need bigger injectors, probably 36lb. And your stock pump may not be able to handle it - it'll be on the edge...
Dave
Old Sep 21, 2003 | 06:38 AM
rskrause's Avatar
Moderator
Dave
Right, but the expensive/complicated part (the stock PCM) can easily be used (with appropriate tuning) to support a 500hp application. I am still using the stock PCM (with a lot of add-ons) to support >800rwhp. There are certainly lots of potential benefits to an aftermarket ECU, but excpet for the 7,000rpm limit, the stocker can do a surprisingly good job in a hi-po application.
Rich Krause
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
