Will I be in the 12's ??? HP estimate ?
Old May 7, 2006 | 11:28 PM
EnerjetF67's Avatar
Building a new engine for my 95 Z28/M6 with the following parts:
030 over LT1, balanced internals that include stock crank stroke cast Eagle Crank, forged 10.5/1 JE pistons, Eagle SIR steel rods, King bearings, Melling high PRESSURE/std volume oil pump.
LT4 Hot cam kit
Mildly ported heads (gasket matched, bowls blended, thinned guides, surfaced, competition valve job w/backcut valves)
MAC mid-length headers w/off-road y-pipe flowing into 3" straight pipe to a 2-chamber Flowmaster
K&N FIPK
Home-brew tune using TunerCAT
52mm TB
TB coolant bypass
MSD coil/Super conductor wires
NGK TR55's
Redline 20w50 oil/AC filter
!Cat
100% STOCK suspension
I'd like to know if I will (or should depending on the driver) be into the 12's in the 1/4 with my combo. If not, what else do I need ?
Also, I'd like a guess to my FWHP and RWHP.
Old May 7, 2006 | 11:42 PM
OrbitalChris's Avatar
Re: Will I be in the 12's ??? HP estimate ?
Oh yeh, youll definitely hit 12s if you get some traction, and you should have over 330rwhp id say, getting some long tube headers would help, definitely rear gears if you dont have them, good luck and let us know how it goes!
Old May 8, 2006 | 09:09 AM
EnerjetF67's Avatar
I currently have 3.42 rear gears; 4.10's are not an option for me as I drive 120mi+ round trip to work every day with this car !
I could go with 3.73's, but I have heard they are not worth the cost over the 3.42's as the gains would be minimal.
I can't go with a full long-tube header because I need the stock ground clearance (once again the 120+miles per weekday over typical lousy Michigan road condtions)
Old May 8, 2006 | 11:50 PM
well if you have 3.42s it wont make that much of a noticible difference, just alittle in the times, lts arent that bad for clearance but whatever you want to do man--good luck just get some good tires/wheels
Old May 10, 2006 | 09:48 PM
matLT1's Avatar
If ground clearance is all thats holding you back on Lt's I wouldn't sweat it. I too live in MI with the mods in my sig and have yet to bottom out my exhaust.
Old May 10, 2006 | 10:12 PM
1SlowFormula's Avatar
I agree with all above you should easily be there maybe even 12s on crappy street tires depending on driver...
Old May 11, 2006 | 03:50 AM
HungryT/A's Avatar
You'll be in the 12's for sure, I managed a 12.55 with a 1.97 sixty with stock shortblock, stock heads and a cam.
Old May 11, 2006 | 04:13 AM
RE AND CHERYL's Avatar
12.97 with current mods in sig.
Re'
IndyZman
Oct 22, 2015 02:17 PM
kirschman
May 1, 2015 10:40 PM
cmsmith
Apr 11, 2015 09:37 PM
warmeck
Mar 8, 2015 08:01 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
