will this help with more HP
Old Oct 28, 2014 | 02:59 PM
94Z28LS1toLT1's Avatar
I was looking online and found this kit at this
websitehttp://www.bbkperformance.com/products/performance-pulley-kits/high-performance-pulley-kits/93-97-lt-1-camaro-and-firebird-aluminum-crank-pulley-kits.html
What i would like to do is get more hp with my car its a daily driver.What other ideas does anyone have that i can do for my car.thank u guys
Old Oct 28, 2014 | 05:01 PM
Re: will this help with more HP
You won't gain much HP at all with an underdrive pulley on the LT1, because unlike all other small block Chevy's, the water pump is not driven off the serpentine belt. It's gear driven off the timing set.
Here's a dyno test with an U/D pulley on an LT1, gained 0.7 peak HP:
Drivetrain Modifications #2
Old Oct 28, 2014 | 05:37 PM
AdsoYo's Avatar
It looks like your car has all the bolt-ons. You could get a mail-order tune or a dyno tune for more power. Might have to start reading up on heads/cam combinations at this point. People around here and other forums seem to like Lloyd Elliot and Advanced Induction.
Old Oct 29, 2014 | 08:57 AM
maybe2fast's Avatar
or an electric waterpump
Old Oct 29, 2014 | 10:42 AM
I don't see that much on the mods list for the engine.... CAI, long tubes, custom tune, and a 58mm TB. First 3 are good, last one is not important. Rest is suspension/chassis. The EGR and A/C delete don't affect performance, other than weight. What about something as simple as the throttle body coolant bypass, 160* thermostat with corrections to the tune to match, or 1.6X full roller rockers w/ LT4 knock module (if you can find one)? What's behind the long tubes - duals or catback?
3.73 or 4.10 gears will really wake it up.
Old Oct 29, 2014 | 08:28 PM
parkers Z28's Avatar
3:73 or 4:11 gears previously posted above !!!! especially since you have most of the suspension up grades
1.6 roller rockers ,springs , cam and a tune... if the money is there cam/heads package from Lloyd Elliott
Old Oct 29, 2014 | 08:37 PM
it does have a 160 t stat forgot that in the signature. what is the throttle body coolant bypass? i think i wrote that one in another thread (tb hose delete) asking what this is and you answered it. Im sorry to ask this are duals two tail pipes coming at the end of the car,and whats catback mean? thank u
Old Oct 29, 2014 | 08:43 PM
Thank you!! and do i just order it from Lloyd Elliiot,what kinda money are we talking about?
Old Oct 29, 2014 | 08:47 PM
moparman's Avatar
The catback is a larger exhaust from the catalytic converter back. Several companies make them, and they produce more power. Here's a link to the Magnaflow. You can buy from anyone you want, as this is just for illustrative purposes.
Hottexhaust - Search Results for "15620 15694"
Old Oct 29, 2014 | 08:51 PM
its all straight pipes and the cats are out,no muffler, i just have the cats sitting in closet till i have to smog the car next year. the guy that sold me the car told me to not to put a magnaflow and to keep the set up the way it is because it will kill the sound that i have to it.i love the sound it has just hope i dont have police stop me for it
Old Oct 31, 2014 | 05:50 AM
maybe2fast's Avatar
http://elliottsportworks.com/
