will this harmonic balancer work?
Old Dec 1, 2004 | 01:36 PM
Seal's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7937089428
will it? I need to know ASAP.... thx
Old Dec 1, 2004 | 02:08 PM
fesgali's Avatar
Re: will this harmonic balancer work?
I don't see why not from it's description and the table, but then again i don't know much about dampers and crank pulleys.
Old Dec 2, 2004 | 07:10 AM
slopokrodrigez's Avatar
The 90030 says it's for INT. balanced engines which if yours is stock, it is externally balanced. Everyone says both should be neutral but in reality, many stock ones are not. Since they went to the trouble of putting just int. balanced on the chart, there must be some difference. Check with the MFR before you bid on it.
Old Dec 2, 2004 | 09:10 AM
Seal's Avatar
well, my engine is being built, so they needed a harm balancer to put on it for balancing, so i guess that wouldnt have mattered, but i found a stock brand new one for 80 bux, so i gott that one
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Jason Short
Jan 19, 2015 06:33 PM
smokin5s
Jul 24, 2003 10:47 PM
1LEThumper
Jul 14, 2003 12:45 PM
