Will ford motor sports injectors work in my lt1?
Old Feb 16, 2004 | 10:58 PM
stik6shift93's Avatar
Just curious, I've heard of people using svo ford injectors. These are out of a mustang 5.0, are the connectors and everything the same? Also I believe ford flow rates their injectors for a lower fuel pressure, what will a 30lb ford injector flow at lt1 fuel pressure?
Old Feb 16, 2004 | 11:04 PM
simple's Avatar
yes, they are what everyone refers to as SVO injectors
a 30# SVO at LT1 FP should be about 32#'s which is usually more then enuf for most NA applications, they are a good injector
stock injectors out of a 5.0 are 19#'s @ ~38psi? they are about the equivelent to stock 22# injectors @ 43.5psi found in the '93 cars
Old Feb 16, 2004 | 11:24 PM
sweet, thanks man
Old Feb 16, 2004 | 11:33 PM
Kryckter's Avatar
Not meaning to steal your thread or anything but I wanted to add onto this. Do you have to get the computer programmed when you sawp out the injector size? Anything else needed for the sawp. i know my mustang only needed injectors and a programmed Mass-Air meter for the injector size
Old Feb 17, 2004 | 06:25 AM
IDOXLR8's Avatar
It really depends on the size of the injector. ANything bigger than a 24 lb injector will need to have the computer reprogrammend.
Old Feb 17, 2004 | 06:28 AM
Fastbird93's Avatar
If you make an injector swap to the same size rating on an SVO, or a larger aftermarket one, then YES get it tuned. You wouldn't believe how much a couple PSI rating difference makes.
When I had my bolt on car tuned, I noticed the injector constant as accidentally set to 24#. Stock 93's have 22#. No wonder I was barely getting 200 MPG on the highway.
Old Feb 17, 2004 | 11:26 AM
marshall93z's Avatar
200 mpg aint too bad...lol!!!
Old Feb 17, 2004 | 11:30 AM
SVT Killer LV's Avatar
I would be on my 30th tank since the car was new...
Old Feb 17, 2004 | 11:52 AM
Fastbird93's Avatar
Sorry guys, I meant MPT (tank).
I was sleepy, just woke up when I wrote that.
Old Feb 17, 2004 | 12:51 PM
Vendetta's Avatar
7:28, damn, I just woke up at 1:30!!! College rules
Old Feb 17, 2004 | 01:29 PM
rkussy's Avatar
Everyone on this board refers to the injectors as svo. Are these the exact same injectors that Summit refers to as Ford racing and the Ford dealers also refer to as Ford racing?
Old Feb 17, 2004 | 03:19 PM
simple's Avatar
yep, SVO is Special Vehicle Operations, now known as SVT Special Vehicle Team, they are the same as the ones in Summit
you can find them cheaper here
Old Feb 17, 2004 | 03:54 PM
rkussy's Avatar
Thanks, thats what I thought I just ordered them for $200. I watched used sets go for 150-177 and figured new with warranty is worth the xtra bucks.
oldschool
Feb 9, 2016 09:21 PM
NewsBot
Dec 3, 2014 12:30 PM
formula218
Dec 2, 2014 04:27 PM
bossco
Nov 29, 2014 10:18 AM
Jul 4, 2005 05:00 PM
