Will exhaust leaks in my y pipe cause the car to lose power?
Old Aug 7, 2006 | 06:54 PM
KillerTA's Avatar
Question Will exhaust leaks in my y pipe cause the car to lose power?
I've got the pacesetter y pipe connected to pacesetter LT's with the slip fit connection and somewhere there is a very noticeable leak.
Is this going to cause power loss because I don't have time, money, or patience to fix it right now if it doesn't need to be.
As far as I can tell, the headers are tight on the heads. I've driven it about 200 miles and the bolts that came with the headers are still in tight.
Old Aug 7, 2006 | 10:29 PM
Re: Will exhaust leaks in my y pipe cause the car to lose power?
If the leak is before or near the O2 sensor(s), its going to cause it to run rich, and that's not going to make optimum power.
Old Aug 7, 2006 | 10:47 PM
speed_demon24's Avatar
I'm guessing the 02 locations are on the header like my jethots on your pacesetters, so the 02 should be before the leak, and as long as the leak isn't big enough to let fresh air reach the 02 it won't hurt power.
MadMav
Feb 6, 2015 11:02 PM
92ragtop
Dec 27, 2014 01:56 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
