Will it cause any problems to delted smog?
Old Sep 18, 2006 | 10:00 AM
udlose94z28's Avatar
Right now i have manifolds, if i block up the holes and take everything off pump and everything..... will it cause the motor to run smoother? or worse? would i need a programmer to take off the check engine light or wat?
Help me out people Thanks!
Old Sep 18, 2006 | 10:59 AM
Re: Will it cause any problems to delted smog?
You can delete AIR and EGR. Neither of those will affect performance, since AIR only works for a couple minutes at startup, EGR never works at idle or at WOT. The only change from deleting EGR might be an increased tendancy to knock when lugging the engine at low RPM, since that's when the PCM activates the EGR system to cool down the combustion chamber temperatures.
AIR will not set a code in OBD-I as long as there is a good fuse in the electrical circuit. EGR can set a code for both low EGR flow and for the missing EGR solenoid (if you delete that too). In OBD-I the EGR flow code is failry rare, but it is possible, and you would need to have it programmed out of the PCM to aboid an SES light and a code.
Why do feel you need to delete these systems?
Old Sep 18, 2006 | 11:52 AM
FuryZ28's Avatar
Simple. Less clutter.
Old Sep 18, 2006 | 10:39 PM
SoloExceptional's Avatar
EGR is very little clutter being it's on the very back of the intake, I regret deleting mine seeing as how it can only help an engine.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
cheapchevy
Apr 8, 2015 08:48 PM
akwa
Apr 5, 2015 05:09 PM
edman
Mar 13, 2015 09:39 PM
alphaauto
Jan 23, 2015 07:42 AM
