will car run with out harmonic balancer on
Old Nov 13, 2007 | 05:14 PM
cruzinMaroZ28's Avatar
i need a answer quick will it run and if it runs how will it run????
Old Nov 13, 2007 | 05:19 PM
It will run, and you probably won't notice its missing. Its not a balancer, its a damper, and it keeps the crankshaft from experiencing large displacement torsional vibrations, which cause fatigue of the metal. Just don't run it too long.
Old Nov 13, 2007 | 05:26 PM
greenmachinedriver's Avatar
you must have at least the hub in place so that it will not puke the oil. would not recomend running for very long.
Old Nov 13, 2007 | 07:40 PM
OBE1 95Z28's Avatar
The balance is also the pulley for the accessory belt, so you won't be charging the battery or have power steering.
Old Nov 13, 2007 | 07:52 PM
77LT1's Avatar
Yea, that will make a mess for sure.
B
Old Nov 19, 2007 | 03:25 PM
djk19's Avatar
Bad Idea Just Dont Be Lazy
Old Nov 19, 2007 | 03:43 PM
96ZCamaro's Avatar
Just put it on. Doesnt take long.
Old Nov 19, 2007 | 07:11 PM
Projectz28's Avatar
Moderator
it will run without it. Obviously none of your accesories will turn because there is no place to run the belt. If you just need to move the car or something it will run and it will be OK to move it. Not recommended to run it for long periods without it for reasons that Injuneer stated.
Oh and the hub thing too
Old Nov 19, 2007 | 10:31 PM
djk19's Avatar
I just did my dual roller timing set, all new clean gaskets on the timing cover, waterpump and new seals for the opti/cover and crank hub/cover. I had to buy bolts that fit the stock hub holes to pull it then I put my fluidampr on without installing the spacer for it that goes up against the crank gear. I pulled the fluidamper and put it back on within the half hour. Taking my time, walkign around and talking to people. It is easy to throw on there. I did not have to use a hub installer because with the fluidampr there is a keyway and the hub can be greased to slide on. then I bought a $30 arp crank hub 12 point bolt with thick steel washer and it looked like it was made for it. I used the fat arp bolt to slowly pull the hub on with a torque wrench and used a lazer level and the belt to make sure it was seated all the way. Came out perfect the second time around and went smooth as could be. The belt tensioner on our cars is the easiest setup as well. One little drive and bend it down. it takes less then 30 minutes...
Old Nov 20, 2007 | 07:09 PM
hopingforz28's Avatar
it will run but you risk the chance of cracking the crank
Old Nov 21, 2007 | 12:27 PM
OBE1 95Z28's Avatar
Pulling the hub in place risks stripping the threads in your crank snout. Use a hardened threaded rod, nut and washers to push the hub in place.
Old Nov 21, 2007 | 12:46 PM
djk19's Avatar
the ARP bolt/washer has a large flat surface that pushes against the fluidampr. the stock setup does not have a very large washer. the setup I had allowed me to use some white lithium on the crank snout, contact surface of balancer and washer contact surface. Nice easy slow turns easily pressed the balancer into place all the way down without any fight at all. I then took the bolt back out and applied a tiny drop of thread locker and threaded it back into place. Worked perfectly. if you re-installing the stock hub you would definately want to use an installation tool for the reasons mentioned. The stock bolt is not a harded arp bolt and the stock hub does not use a keyway and should not have too much grease on it so it does not slip around once installed so doing it my way would be risky. Lowes has the parts to build the hub installer. I was close to settig it up but realised I could do what I did. So I did*
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
smokin5s
Jul 24, 2003 10:47 PM
Brent94Z
Mar 21, 2002 04:44 PM
