Will 95+ vented opti fit a '94 non-vented opti setup
Re: Will 95+ vented opti fit a '94 non-vented opti setup
To do this you will need the 95+ timing cover, 95+ timing chain, longer dowel pin in the cam, and the 2 vacuum lines. IMO, it's not worth doing unless your doing a cam swap.
The 93-4 cam does not have the 'nose drilling' that the vented opti requires..
stockssn2o
May 25, 2015 08:54 AM
