Will 95+ vented opti fit a '94 non-vented opti setup
Old Aug 26, 2005 | 03:36 PM
Mikes 1994 z28's Avatar
Are there any modifications that need to be made to do this?
Old Aug 26, 2005 | 03:53 PM
redcamaroz28's Avatar
Re: Will 95+ vented opti fit a '94 non-vented opti setup
To do this you will need the 95+ timing cover, 95+ timing chain, longer dowel pin in the cam, and the 2 vacuum lines. IMO, it's not worth doing unless your doing a cam swap.
Old Aug 26, 2005 | 04:02 PM
BlackScreaminMachine's Avatar
http://para.noid.org/~muttvette/opti.html
this pretty much explains it.
Old Aug 26, 2005 | 04:43 PM
FutureZMan's Avatar
Old Aug 26, 2005 | 05:29 PM
RedlineJesse's Avatar
Good luck !!!!!!
Old Sep 2, 2005 | 01:19 PM
Mtrhds94Z's Avatar
Not only a longer dowel pin, but another cam..
The 93-4 cam does not have the 'nose drilling' that the vented opti requires..
Old Sep 2, 2005 | 03:34 PM
Mtrhds94Z: Your right, I just looked at the stock '94 and '96 cams i have in my garage. Cool, I learned somethin new today
Ryan
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
*Emilia*
May 13, 2015 09:05 AM
