will a 95 pcm/harness work in a 96
Old Mar 30, 2004 | 12:05 PM
sharp396's Avatar
Does anybody know whether a pcm and harness from a 95' M6 will work in a 96 M6? Some of my pins broke off of my pcm in my harness and I can't get them out.
Thanks, Aaron
Old Mar 30, 2004 | 12:57 PM
A 95 harness will not have all the wiring in it a 96 has. There were additional items added because of OBD-II.
Old Mar 30, 2004 | 01:29 PM
sharp396's Avatar
Thanks shoebox. Will the pcm work, or is it OBD-1 too?
Old Mar 30, 2004 | 03:05 PM
A 1995 PCM is OBD-I. You could get by if you swapped both harness and PCM. There would be a few things on your 96 engine that would not be reconnected (like crank sensor, rear O2s, EVAP vacuum switch...maybe another thing or two). You would also need an OBD-I knock sensor for the block.
I think that should work. Someone correct me if that is wrong.
Oh, the coil connector is different, so you might need to adapt or change the coil.
Old Mar 30, 2004 | 08:08 PM
sharp396's Avatar
Ok. Thanks. I will just try to find one from a 96.
Old Apr 1, 2004 | 08:15 AM
Thirim's Avatar
uhh? coil connector different? pls explain... just the connector or the coil itself is wired different.. I have a 96 Harness and a 96 Engine.. going 94PCM though..
Old Apr 1, 2004 | 08:17 AM
Pre 96 use a dual connector coil and 96 and up use a single connector coil. If all you are doing is changing the PCM, you don't have to worry about it.
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
