will a 95 pcm/harness work in a 96
Does anybody know whether a pcm and harness from a 95' M6 will work in a 96 M6? Some of my pins broke off of my pcm in my harness and I can't get them out.
Thanks, Aaron
Thanks, Aaron
A 1995 PCM is OBD-I. You could get by if you swapped both harness and PCM. There would be a few things on your 96 engine that would not be reconnected (like crank sensor, rear O2s, EVAP vacuum switch...maybe another thing or two). You would also need an OBD-I knock sensor for the block.
I think that should work. Someone correct me if that is wrong.
Oh, the coil connector is different, so you might need to adapt or change the coil.
Originally posted by Thirim
uhh? coil connector different? pls explain... just the connector or the coil itself is wired different.. I have a 96 Harness and a 96 Engine.. going 94PCM though..
squarehead
Jan 15, 2015 07:02 PM
