Will a 94 timing set work on my 96??
Old Mar 10, 2004 | 01:06 AM
Muskys SS's Avatar
Will it work with a vented opti??
I also purchased a hotcam out of a 94 so, would I still have to change the dowel pin If I was to get the 94 timing set???
Old Mar 10, 2004 | 03:23 AM
scoobysnax83's Avatar
you're gonna have a problem with the timing cover, cam and opti. But, all can be remedied with the timing cover. If you get a 94 style timing cover it will work with the timing gears and chain you have, but you need an unvented opti to work with the 94 Hotcam.
You sir, are a$$ backwards Just Kidding
Old Mar 10, 2004 | 07:51 AM
You would definitely need to check the dowel length and I also think that the early cam gear may not work because the hole in the middle of it is splined for the older opti drive. That hole in the gear may not be big enough for the stub on the vented opti drive to pass through it. IMO, don't mess with using the early timing gears.
Old Mar 10, 2004 | 09:56 AM
Muskys SS's Avatar
Thanx for the replies guys. I'll hold out on the purchase of the timing set.
Old Mar 10, 2004 | 09:57 AM
Muskys SS's Avatar
The hotcam will work, I just have to change the dowel pin to the 96 length.
Old Mar 10, 2004 | 01:10 PM
JasonL's Avatar
I guess it's moot now, but the '94 timing cover would also be missing the OBD2 crank position sensor, right?
Old Mar 10, 2004 | 01:27 PM
Mtrhds94Z's Avatar
Right 93-4-5 no CPS in TC..
Red Hawk 94
Mar 18, 2019 04:03 PM
parkers Z28
Mar 11, 2016 08:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
omarECD
Aug 19, 2002 07:28 AM
