will 30# injectors be enough
Old Jul 24, 2004 | 09:31 PM
97Z-M6's Avatar
will 30# injectors be enough to support 450rwhp
Old Jul 24, 2004 | 09:33 PM
med_reject's Avatar
Re: will 30# injectors be enough
30# svo will just barely do it.
Old Jul 24, 2004 | 11:57 PM
Somnambulist's Avatar
it would probably be better to run 36#ers at lower impedence than 30#ers at higher...
Old Jul 25, 2004 | 12:13 AM
Say what.....???
You don't get into an issue with injector impedance (low vs. high), until you go over 42#/HR, where the stock PCM can not drive low impedance injectors without a "black box" convertor.
Or is it possible you meant to say to use a larger injector to get a lower "duty cycle".... that would make sense. And I would agree with the 36#'s as being preferred at this HP level, for that reason.
Old Jul 25, 2004 | 12:14 AM
my mistake. I was referring to the 'duty cycle'
Old Jul 25, 2004 | 09:00 AM
97Z-M6's Avatar
will lucas injectors work in our cars.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
